custom shaped LED fixtures
  • modulight
    by modulight » Thu Jan 17, 2013 2:46 pm
    The fixture editor and DMX control is a great feature, but there is one limitation. You can only create fixtures in a rectangular shape. The LED units we make are hexagonal shaped, so there is no way for us to create a fixture using the current fixture editor, unless we create them using lots of single pixel fixtures, but that would be very time consuming for large installations!
    - We'd like the ability to manually lay out the pixels within a grid.
    - not all the spaces in a grid should be assigned DMX channels, ie blank space.
    In our case the hexagon unit has 19 RGB pixels. To fit that shape into a 9x5 grid we space them out within the grid.
    See below where + is space, and 0 is an LED:
    ++0+0+0++
    +0+0+0+0+
    0+0+0+0+0
    +0+0+0+0+
    ++0+0+0++
    Defining this in the fixture editor would be nice, but I'd be happy defining it in an XML like structure or whatever as long as it can be imported to madmapper.
    See http://www.modulight.jp/Showreel-2012 for more info on specific use case.
    NateMac
    Re: custom shaped LED fixtures
    by NateMac » Wed Jan 23, 2013 2:26 am
    I wanted to second this:
    Just like how we can have a projection surface that is a circle, instead of having just straight lines for fixtures, to have; Arc's, Curves, and Circles for fixtures to follow.
  • jskyhawk
    by jskyhawk » Tue Jun 24, 2014 3:48 am
    +1
    by sigmasix » Wed Jun 25, 2014 11:45 am
    lastest version of madmapper can do that
  • Dawidosza
    by Dawidosza » Thu Nov 13, 2014 10:15 pm
    +2 :)
  • MoToMoToM
    by MoToMoToM » Fri May 24, 2019 8:06 pm
    same problem! we have quite a lot of work making circles from straight lines fixtures. goes hand in hand with a large amount of methematics :O
    by franz » Mon Jun 03, 2019 4:33 pm
    you can import CSV fixture definitions if I recall correctly,
    I'm just having a hard time finding the tutorial and pdf we did on the subject.
    by franz » Mon Jun 03, 2019 4:38 pm
    did not found the csv tutorial yet, but check here:
    viewtopic.php?t=9953
    https://github.com/alex-Arc/madmapper-csvGenerator
    and for svg import:
    https://vimeo.com/202367567
Users browsing this forum: No registered users and 57 guests
